Using relations to set family table values
Hi
Does anyone know if it is possible to set the YES/NO values for features in a family table, using relations?
Currently, I am assigning dimensions according to conditional statements and would like to do the same with the features themselves, but am unsure if this is possible.
res520
res520
RE: Using relations to set family table values
-Hora
I have relations in the part that set dimensional values according to an overall dimension value that varies between instances. An example might be:
IF d10 < 1400
d62 = 600
ELSE
d62 = 800
Where d10 is the varying (between instances)overall dimension, and d62 places a feature at a given position.
I wondered if it may be possible to include another line in the conditional statement that may set the Y/N value of a given feature at the same time. I am hoping this may reduce manual editing of the family table.
Any ideas?
Thanks again
res520
p.s. Running Pro-E 2001 on Win2000
You cannot add a conditional statement in a family table. But you can add your d10 parameter in the family table and you can give it specific values.
Keep the relation
IF d10 < 1400
d62 = 600
ELSE
d62 = 800
in the generic and the instances will update the d62 value.
-Hora
