"calcualtion of solution gas oil ratio "
dear freinds
i want to design pipeline for two phase flow(oil-gas) by a computer program
so the first think  in such case is to find a correlation
by which one can calculate the dissolved gas and formation volume factor and other properties that dependent on pressure and temperature. i uesed Vasquez-Beggs Equation,published  in 1980 in jpt .this equation is as follows
Rs = C1 x gamma(gas) x p ^ C2 x exp [ C3 ( gamma(oil) / T + 460 ) ]     --1
gamma(gas)here is a gas gravity(air=1) that would result from seperator conditions of 100 psig
c1,c2,c3 are constants depend on API
P,T:average pressure and temperature at any pipeline section.
how one could obtain this gamma(gas),for pipeline case?
thanks
RE: "calcualtion of solution gas oil ratio "
a cut and paste from the API excel sheet to estimate oil storage tank break out and flashing losses.
FLASHING LOSSES USING THE VASQUEZ-BEGGS EQUATION
Vasquez-Beggs Equation            Value    Equation                            Reference
Q=    Annual Production, bbl/yr        184.52
APIG=    API Gravity (Degrees)        50    From liquid analysis
C1=    Vasquez-Beggs Constant        0.0178    If API Gravity >30 then C1=0.0178, otherwise =0.0362                            Table 22.6, pg. 22-8 PE Handbook
C2=    Vasquez-Beggs Constant        1.187    If API Gravity >30 then C2=1.187, otherwise =1.0937                            Table 22.6, pg. 22-8 PE Handbook
C3=    Vasquez-Beggs Constant        23.931    If API Gravity >30 then C3=23.931, otherwise =25.724                            Table 22.6, pg. 22-8 PE Handbook
AD=    Air density @ 14.7 psia and 60 F (lb/cu.ft.)        0.076318    Default =0.076318                            Table B-2, Air Pollution Control (Cooper & Alley)
T=    Fluid Temperature in vessel        60.25    Default =100 F
VP=    Upstream vessel pressure (psig)        30    Default =30 psig
UP=    Upstream pressure (psia)        44.7    UP = VP + 14.7
SG=    Specific gravity of gas in separator (Air =1)        0.71    From gas analysis
CSG=    Corrected specific gravity of gas        0.6582    CSG = SG * (1.0+5.912E-05*APIG*T*Log(UP/114.7))                            Eq. 11, pg. 22-7, PE Handbook
GD=    Gas Density (lb/cu.ft.)        0.0502    GD = CSG * AD
GOR=    Gas to oil ratio (scf/bbl)        10.6312    GOR = CI * CSG * UP^C2 *EXP ((C3*APIG)/(T+460))                            Vasquez-Beggs Correlation Equation (1)
E=    Control efficiency (% Reduction)        0    Default: 0
Lf=    Correlated Flashing Loss (lb/yr)        98.54689348    Lf = GOR * Q * GD * (100-E)/100
Lf=    Correlated Flashing Loss (tpy)        0.049    Lf /2000 lb/ton
(1) Gas to oil ratio (GOR) is calculated using the Vasquez-Beggs Correlation; equation (17), pg. 22-9 PE Handbook
thank you very much dear for your helpfull aid
PE handbook its short for petroleum engineering handbook ?
what is the the name of the author?
thanks again
