Were are my files????
I recently started a new job and we are running solid edge for the first time on a network that only had AutoCAD before. My previous company had SE, but I don't remember having this problem.
When I first start my machine things are going great. But as I work I notice that things seem to slow down. It takes longer to go update parts and things like that.
Eventually I get an error that the file I am looking for can't be found. I exit SE and try again, but it's still the same. This usually happens with a draft first, and I can't open the assembly or any of the individual parts. I restart my machine and then it's fine, for a while.
Does this sound like a set-up issue with my machine running SE, or could this be a network issue that I should let the IT guys figure out.
RE: Were are my files????
How much VM do you have allocated?
What version of SE & Patch are you using?
I'm running Windows 2000 profesional.
I have 4092meg of VM.
I'm running SE version 14. It's a demo version that our reseller gave us to get started with while our purchasing people set things up.
I don't know anything about the network we are using.
I hope this helps.
It doesn't sound like a network problem ... if it was, I think the problem would be there from the start. It wouldn't hurt to get your IT guys involved though.
Have you loaded whatever SE14 patches exist?
Does the graphics card have a specific setting for SE?
