thermodynamic data
thermodynamic data
thermodynamic data
Does anyone know of a good source of Gibbs free energy data for compounds of managanese, chromium, silicon and sulfur and oxygen?
RE: thermodynamic data
Heat of formation and coefficients a, b, c and I of free energy written as delatS=-a-2,303*a*logT-2*b*E-3*T+c*E-5*T^(-2) -I for those oxides you can find in Handbook of Chemistry and Physics, The Chemical Rubber Co,lobrary of Congress Card No 13-11056.
M777182
For Mn, following A+B+CTlogT, depending on the temperature range, use the CRC Handbook of Chemistry and Physics. For others, the same handbook gives the standard values at 298.15 K in kJ/mol.
depends on the temperature range you are interested in
Thanks to all. I was able to find the necessary data.
If you need similar again try:
DMIC Report 224
February 1, 1966
Ignition of Metals in Oxygen
Defense Metals Information Center
Battelle Memorial Institute
Columbus, Ohio
A boat load of thermophysical property data.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
