Automated Work Instructions?
Hi there. I am currently working on creating some "work instructions" for our assembly area at our factory. I was originally going to just type these out and maybe copy and paste some digital pictures next to the appropriate step. Then, one of my colleagues had mentioned the possibility of using a software package that creates work instructions in an "easy-to-read" format without much thought by the guy writing down the steps, me. I was unsure if any of you had used software for writing instructions like this or if you knew of any good packages yourself? I would really appreciate some feedback on what works/worked for you all. I have basically only heard of one brand, Talsico, but I am sure there are others...right? Thanks in advance.
Signed,
Zack
Signed,
Zack
RE: Automated Work Instructions?
I've written a lot of operating procedures, user manuals, and other boring technical documents. I've never had much success getting them written by "Technical Writers", so I would be extrememly sceptical of letting a program have a go at it.
I've never used any of these programs, but it seems to me like you would spend more time describing the process to the robot than it would take to write the document yourself.
I've used the digital picture method for the last few years with good success. One thing that really works well is to use PhotoShop or PictureIt! (or even PaintBrush) to annotate the pictures with words and arrows to make your points clearer. I've gotten very good feedback on that technique.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
-Zack
TTFN
Who will proof-read it? How many pages (lines) does it take before the proof-reader gives up? This sounds pretty much like handing over technical translations to a translator that knows about languages, but very little about the technology. The result is almost always completely useless. And automated translators do not produce better results. Only more consistently bad.
There are some good texts (sorry, I only know Swedish texts) that introduce you to manual writing and instruction writing. There is usually a fair bit of report writing in there as well.
A problem I have with these jobs is to decide what I am writing. Is it an Operator Manual, a Repair Manual, a Sales Leaflet or a Systems Description? And also what level will my reader be at? Can he be expected to know the jargong of that technical field or do we have to use "normal words"? The latter alternative will make an experienced person think that the guy who wrote the text is a novice while the former will make the text incomprehensible - and thrown away.
My first step therefore is to interview the people that wants the text written. But before putting any questions, I make sure that he understands why I need the information. The answers otherwise tend to be guesses and excursions into irrelevant topics rather than the information needed.
The next step is to write up a couple of short examples. Like tis:
A) Connect ground lead to motor frame
B) Set 200 V/us
C) Touch shaft with probe
D) Read counter
E) If ctr < 1000 PPS the drive is OK. If > 1000 the drive needs to be examined more closely. Make note in test protocol.
G) Remove gnd lead and put Bearing Predictor back in box.
Or this:
"The Bearing Predictor is a device that detects and counts EDM (Electric Discharge Machining) in ball bearings and roller bearings. It does so by evaluating the voltage that exists between motor shaft and motor frame. The signal (voltage) is picked up from the shaft by the Probe and the reference voltage (ground) is taken from the motor frame. A level discriminator outputs a pulse whenever the set level (V per microsecond, V/us) is exceeded and the pulses are counted and displayed. The unit used is Pulses Per Second (PPS). As a rule-of-thumb, 200 V/us and 1000 PPS are critical values. If you measure more than 1000 PPS at 200 V/us, the motor and drive merits a closer examination. If below 1000 PPS at 200 V/us, you are on the safe side."
This doesn't take long. Ask the client which one he thinks is right. Make sure that he understands that there are intermediate levels.
Notice that the first example does not say anything about why this test is being done and it says nothing about the principles. But the guy who reads the instruction will probably be able to do the job. But he is likely to be lost if something unexpected turns up.
The other example does not tell anything about how the measurement shall be made. It does not even tell the guy to connect the probe to the shaft, but he will make the test and he is prepared to deal with unexpected deviations from the norm.
OK, this ran a bit too long. And probably off topic as well. I think that it is clear that I do not believe in automated instruction writing - or translation.
I have recently prepared WI for assembly of components on a prototype vehicle. The components were developed in Pro/ENGINEER. The WI were MS Word documents detailing the assembly instructions with color images captured from Pro/E. I manually labeled the part numbers in Word over the image. It would have been nice to capture some of the assembly steps in notes in Pro/E and/or produce animated assemblies that documented the process, but this would have been overkill.
The best part of the WI process was when I attached additional copies of the colored images with the part numbers to the frame with duct tape. That was the part the technicians appreciated the best!
My suggestion would be do try to develop text of the WI for each step concurrently with the design and codify the statements so the text and images can be assembled into perhaps an HTML format with some automation. A good PDM/PLM tool might be able to help here.
Good luck!
Best regards,
Matthew Ian Loew
"I don't grow up. In me is the small child of my early days" -- M.C. Escher
Bung
Life is non-linear...
Use the "Right click, Format Pictures" to make the format of the pictures the way you want.
Float over text or wrap around.
Also, lock or unlock picture moving with text.
I like to do the Shop Travelers in a "Table".
The text blocks can be controlled easier that way, and alignment is guaranteed. If you need to add a digital photo or even do a stick drawing (I keep the "Draw" toolbar open), add a new row and make it as large as required. Format the picture to "float over text", but lock it to the text. Add text boxes and draw right on the photo, then group the items.
It really works well and doesn't require additional funding for special programs.
A template can be made easily, but don't forget to proof read!
MS Word is quite flexible.
Even on a MAC.
Rerig.
