Part list fields
Part list fields
Again troubles with those iproperty fields. We have used the Authority field in our parts and assys and now it should be seeing in part list of assembly. Only problem is that it's not in the column chooser list. Same problem in the design assistant, half of the fields are missing. This is in inventor 6. Why aren't there all the fields? Saving some bytes of diskspace?
Any idea how to fix this, or just get the authority to partlist?
