System requirements CRT/Flatscreen
Hi to you all
In the process of purchasing a system  for 2D cad 2000 to use at home.  I am undecided whether to go for a flat screen as opposed to a crt. The reasons being footspace and weight of a 19"crt against the price of a 17" flat.  Any info regarding graphic card requirements to give acceptable resolution for cad would be appreciated.  I have heard about problems using Cad with Xp as the OS. Has anybody had any problems with it.  With cost being an issue as well I have just read an article regarding good deals on refurbished m/cs from the likes of Dell and Mesh with what seems good guarantees. Any feedback on the system and best purchase options people have had would be a real help.
Many thanks
RE: System requirements CRT/Flatscreen
XP Pro works very well with Autocad.
Flat screens are good, get the best you can afford.  The cheap ones are not suitable.
LCDs have fixed resolutions so keep that in mind. Some of the LCD models are poor when viewed from a slightly skewed angle. I would try to actual see the model you want to buy before you get it. CRTs give you a lot of bang for the buck and we have found that they are a little more reliable. At work here, we relegate LCDs to the managers and CRTs to the engineers. That is my only experience with them. AZATEK.com is a good place to find deals on monitors BTW.
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
