Hole Dimension Table (Interactive Drafting)
Hi folks,
Does anyone know how to change the number of decimal places within a Hole Dimension Table? I need to show trailing zeros within the table.
RE: Hole Dimension Table (Interactive Drafting)
Change the precision before you create the table.
Precision field is grey then have a look in tools/options/ drafting
go to Administration TAB
Use STYLE values to create new objects = OFF
Eric N.
anyone have ideas?
Thanks.
Which CATIA level do you use ?
INDOCTI DISCANT ET AMENT MEMINISSE PERITI
Eric N.
catiav5@softhome.net
V5 R2 or V5 P2 Rxx....
P stands for Platform, P1,P2 or P3 usually P2 (student version P1) ; Rxx is the Release, R14 is current one
Check in Help/About CATIA V5...
Eric N.
CATIA Version 5.13. Service Pack 6. Build Number 13.
In tools/options the user interface style is P2 (not sure if that is the same as platform level)
Thanks.
-- Jay
So it should work...
1) select points
2) change the number of decimal
3) clic the function to get coordinate in table
4)...
Trailing zero are added manually in R12 SP4. I don't know if you can define that in a parameter somewhere in R13.
Eric N.
I tried exactly what you said and I still don't get trailing zeros. I've alsow tried selecting the table after placement and tried to change the decimal place drop-down box and it makes no difference?
It's not a huge deal, I just happened to come across this thread and wondered if someone knew how to get this to work because I had tried every obvious thing I could and it still wouldn't work.
