Sketch Offset Spline
Help...
Is there any way to offset a spline in sketch mode (Solidworks 2003 SP1) or do I have to re-sketch the projected outline of my model with arcs and lines?
OR -
Can I convert splines to something else that can be offset
Any help appreciated,
Rob
OR -
Rob
RE: Sketch Offset Spline
loooong workaround
•Make an extruded surface from your spline sketch
•Offset the extruded surface as needed
•Use edge of offset surface in a new sketch
Mucho Gracias
Rob
