Collision with an Incompressible fluid
Does anybody have equations for the loads imparted on an object when it collides with water? In particular I am interested in the forces that a torpedo would see when launched from a surface vessel into the ocean while the vessel is traveling at a high speed. I’ve found a couple of papers close to what I’m looking for, but no love! Thanks a lot.
RE: Collision with an Incompressible fluid
Why not think of the situation as a high energy impact and develop the argument from first principles, work-energy, dynamics, etc?
Sorry I could be of more assistance, but I also look forward to the replies. Just out of curiosity, what type of cruising velocity, estimated depth at launch and that sort of thing?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
The first site gives you enough information that you could calculate the impact for different torpedoes.
http://www.warships1.com/Weapons/WTUS_WWII.htm
http://www.ww2pacific.com/torpedo.html
Failing that
For an initial velocity of 25 m /s and a torpedo 5m long we know the collision time is of the order of 0.2 seconds, and so the decel is of the order of 125 m/s/s. This is basically a car crash, sounds about right.
The torpedo weighs say 1000 kg, so that'd be around 125kN
ish. I'd multiply it by 3 or so to get a likely peak force, and knock a bit off becasue the torpedo does not stop dead on entry into the water, in fact at higher speeds it might well plane for a while before sinking. Planing forces can be calculated using the Savitsky Brown equation.
The historical evidence is that you can design torpedoes to be launched at MUCH higher speeds than this, and of course Barnes Wallis's bouncing bomb experiments would give some estimates of the forces involved. Also you might want to look at diving shells, used by some battleships up until the end of WW2.
Cheers
Greg Locock
There is a picture at the warships1 board in a link off unclesyd's URL, showing the torpedo launched at a very low horizontal velocity, such that it basically fell out of the end of the tube, and landed flat in the water. This would be ideal from the point of view of minimising the shock to the torpedo.
Cheers
Greg Locock
http://imarine.mit.edu/ilearn/Web_course/imp-lec1/Introduction/node5.html
