Tearout stress calculation on hole near edge
I am calculating the shear stress of a pin tearing out of a hole that is near the edge of a plate. Does anyone know if the area used in the tearout shear stress calculation would be based on 2 times the distance from the center of the hole to the edge of the plate times the thickness of the plate (as is done with padeyes)? Or would it be based on 2 times the distance from the edge of the plate to the radius of the hole times the thickness of the plate?
Also would there be a limit as to how close the hole could be to the edge without causing a problem with tensile stresses on the section that is between the hole and the edge of the plate?
Thanks in advance for the help,
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
RE: Tearout stress calculation on hole near edge
The formula for shearing out of a fixing to the edge of the plate is :-
F= allowable shear stress in plate * 2*e*t
where F is the force to cause failure
e is distance from fixing centre
to edge of plate
t is the plate thickness
It is normally reccomended that fixings should be at least
(1.5 * "diameter of fixing") away from plate edges.
regards desertfox
desertfox provided the answer for tearout analysis, which agrees with your first item. Your second item is for plate fracture, which may be the limiting condition for your item. It is necessary to check both of these (and bearing yield and pin shear) to avoid failure.
Cory
Cory,
How would you check for plate fracture?
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
S = F/[(W-d)t]
where
d = hole diameter
F = applied force
S = plate stress
Sf = plate fracture stress
t = plate thickness
W = plate width
This is a simple analysis that ignores stress concentration.
Cory
Desertfox,
What if the hole was very large in order to accept a large pin that was required to resist bending. Would the rule of thumb of placing the center of the hole 1.5*D from the edge still apply in that case? It seems that it would be too large a distance?
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
The formula I posted yesterday is based only on tensile loading of plates held together with rivets.
If your encountering bending loads then the situation is different. I need more detail about what your application is and how the load is transfered to the pin.
regards desertfox
I have a large pin in a hole near the edge of a plate and the force on the pin is pulling the pin towards the edge of the plate. I was only suggesting that the 1.5*D distance to the edge of the plate could be much larger than needed if the hole was very large based on the pin needing to be large for other reasons.
Your thoughts?
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
If the pin is trying to shear out through the plate then I would stick to the 1.5*Diameter of the pin.
regards Desertfox
Regarding the comment by Desertfox,
(1.5 * "diameter of fixing") away from plate edges.<
Is this distance from the center of the round pin to the plate edge, or is it the distance from the OD or quadrant of the round pin to the plate edge ?
If I have a .125" OD pin ...
.125 X 1.5 = .1875" from edge of plate to center of pin ?
John
Regarding the formula given by desertfox,
to edge of plate
t is the plate thickness<
Do you just use the shear stress in PSI, and this gives you the tear out load force in pounds ?
If I have a rectangular plate 0.1181" thick, .1875" wide, and say 3" long, and I have some .125" OD dowels running lengthwise down the center of the plate, with the plate having an allowable shear stress of say 20,000 PSI, I calculate...
20,000 PSI * 2 * .09375 * .1181 = 442.875 pounds to cause the dowel to tear through the plate across the .1875" width ?
Is this the correct approach based on the formula ?
I am also interested in learning more about the method from the AISC design manual if possible, I don't have the manual for reference.
John
Your understanding of the formula is correct, however if you follow the reccomended edge distance to the dowel fixing centre you won't need to worry to much about a tear out failure.
regards
desertfox
