dim angle as inclusive
I have a lead-in on a hole. The lead-in is 30° from center out. I would like to show the angle as 60° inclusive. Can someone explain if this is possible.
RE: dim angle as inclusive
If you have used the hole feature this should come over as standard.
If you have created a cut on the hole, you can create a dimension by selceting the two edges of the lead in.
Hope this helps.
maybe only a drafter
but the best user at this company!
Then, convert this single line entity into a construction line (Select-->Right Click-->Toggle Construction).
You can now create the 60° dimension between the original and the mirrored entitiy.
Hope it helps :)
Mark
