Unsorted nodes
Unsorted nodes
Unsorted nodes
I can't find a way to create unsorted node sets in CAE. It seems to automatically sort the node set numerically. This becomes a problem when using MPCs between two node sets. Any ideas on how to do it within CAE only?
Any suggestions would be great.
RE: Unsorted nodes
There isn't. You'll have to manually order the nodes yourself within the .inp file after it's been created. You might find that the nodes follow a pattern anyway and the only modification to the sequence may be at the end nodes of the line(s).
corus
