How do I draw 3d pipes/ducting in autocad 2002
I am struggling to draw 3d pipes in autocad 2002. Has anyone got advice on how to actually do this?
RE: How do I draw 3d pipes/ducting in autocad 2002
I think using sweeps would work best. Basically you draw a polyline to represent the path, fillet your corners to have the correct radius for the size pipe you are using. After that you basically draw a profile (circle in this case) to sweep along the path. Look up "sweep" in help if you need a little help with the command.
Good luck.
