Invalid Naming Data?
V5R13 on a wintel machine is giving intermittent errors on file save, and, or open.
It looks like the file will display (on open), but just before it pops up a dialog box that says:
Error: Invalid naming data. Document cannot be read.
It can't be talking about the filename, as I have changed it to a simple, 3 character name followed by .CATPart.
I've moved the file to a local folder and it makes no difference.
Is there anyway to "clean" the file? Am I SOL?
TIA.
RE: Invalid Naming Data?
TOOLS/UTILITY/CATDUAV5
You may need to run a file 3-4 times, check the report.
