HVOF Spray Coating
HVOF Spray Coating
We use a company at the moment to repair our valve components with the above mentioned process. The most common of the coatings being tungsten carbide. Our problem is that the companies spray application can only handle outside diameters and internal diameters of fairly small depths from the end faces. The company had told us that once upon a time they used to be able to but had all kinds of problems with the angle tha coating was being applied at.
Can anybody advise of any reputable companies (preferably local....scotland) that have a successful record of HVOF applications on internal faces?
Rgds
MAB
Rgds
MAB
RE: HVOF Spray Coating
