CosmosWorks 2003 Thin Plate Analysis
I have recently done an analysis using CosmosWorks 2003 on a 24"x36"x0.018" (26 ga.) plate that is fixed on all 4 edges with a 0.46 psi pressure on the face and is 304 SSTL. I used the mid-surface mesh type with a pretty fine mesh size. The results were very surprising. Cosmos calculated a max deflection of 23" and a max stress of 3.28x10^6 psi (ultimate for 304 is 75000psi per Cosmos). This just seems wrong(24"x30" plate physically tested at 0.36" deflection).
Why is Cosmos producing such a result and is they a way to properly analyze this scenario?
Small Deflection Theory vs Large deflection Theory of Plates???
Any ideas would be helpful.
Thanks Neil
Thanks Neil
RE: CosmosWorks 2003 Thin Plate Analysis
<Forum727>
http://www.EsoxRepublic.com
In order to properly do your problem in FEA, you must have the non-linear package. For the equations that will help you do this as a hand calc, do a google search for "Timoshenko plate large deflection"
