Material build up on the die in extrusion
Is there anything that can be done to reduce or eliminate material build up on the die in extrusion process? The material used is a mix of natural rubber with polypropylene.
Thank you!!
Thank you!!
RE: Material build up on the die in extrusion
nick
Thanks again
Gerardo
its quite expensive, but compared to time lost lifitng out dies to clean them its a good cost saving.
Malcolm
There were several purging compounds out there but we used this one with good results.
http://www.rapidpurge.com
patrick De Belder
