spring question
spring question
spring question
I have modeled a helical spring and want to place it in an assembly is there any way to make the spring compress like an actual spring within the assy?
Thanks again
RE: spring question
Check out Thread559-91266. It answers the exact same question from a previous post.
from (the City of) Barrie, Ontario.
If you choke a smurf,   what color does it turn?
RE: spring question
There is a torsion spring model posted at <http://esoxrepublic.com/models>.  One of the features of this model is that its length is controlled by the length of a sketch segment.  Perhaps you could make use of this.
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
