Small Heat Exchanger Cores
With the multitude of forums this could be placed in, I decided to place it here to hopefully get some ideas.
I'm looking for small (compact) heat exchangers. Tube and fin or similar design.
They do not require end tanks, and thus modular sections are workable.
Any ideas would be greatly appreciated.
RE: Small Heat Exchanger Cores
If a design book then refer to Compact Heat Exchangers by Kays and London.
A manufacturer then go to
http://www.alfalaval.com/scripts/WebObjects.dll/ecore.woa/wa/showNode?siteNodeID=5364&contentID=-1&languageID=1
In my application, coolant will be passed through the "tubes" and air across the fins.
The air side must have as low of pressure drop as possible.
Single pass (in one side, out the other) is what I am hoping to find.
We build Fin & Tube Heat exchangers with very low pressure drop on the Air / Fin side. Name your materials!
Contact me devans@elfin.co.uk
I'm off on vacation from june 5th till june 14th.
Try the names: Modine, Heatcraft, Thermasys, Alpine, Super Radiator (phx.srcoils.com).
We have talked to or worked with all of these at one time or another.
Griffy
