Multi server for pdmworks
hello all
we have 3 session in our factory with completely different activities on solidworks ...
so every session must have it's admin and clients ...
so is it possible using just 1 pdm service and 1 computer for vault data , but have 3 admin which shouldn't see themself in pdm.
really I want to not have admin permission equal for 3 admin so i can use 1 server for all.
If it's not possible , is it possible to use 1 server for every session but link between them so clients could access other session project if that admin permit them ?
RE: Multi server for pdmworks
To let your clients see the vault you would need something like Web portal.
Bradley
maybe I wrote badly ...
really there is 3 session : session1 , session2 and session3
there are diffrent from each other.
so thay have 3 admin : admin1 admin2 and admin3
and their clients : clients1 , clients2 and clients3
and they own servers : server1 , server2 and server3
1st question is : how can I merge 3 servers without any other affection ? (because of limitation of hardware existance and back up processing it's better to have just 1 server)
2nd question is : I want a master administrator in vault so he can permit middle administrators to define their clients ..
e.g: master admin defdines 3 admin ,
every admin define it's clients and permission ..
but the admins can't omit other admin , really they even can't see another admin in vault ...
Best regard
To merge 3 data bases into one. If none of the servers have any common data your job will be easier. SolidWorks PDM has a balk check-in that works well.
I do not have an answer for question number 2. We rely on trust, that an administration person does not omit other admin’s.
Bradley
do u have an idea for my problem on this thread ?
