Change The Integer Into Text
Hi Everybody,
Please help me to solve this problem. I have a loop and I want to show the indicator of the loop as a text in a location of my figure. For example, think that my loop is running from p=1:300. I want to be able to show the number corresponding to "p" in each iteration. I know that I can use "TEXT" command but the problem is that in this command I can only use text format not integer format. I hope the problem is clear for you know. Please help me to solve this as soon as possible.
Thanks in advance for your attention.
Amir
RE: Change The Integer Into Text
Hello Amir!
Just use the int2str(p) command.
KaSt
