save matrix into .txt
I imported a tif-file into matlab and would like to save the resulting huge matrix as a txt file with numbers and tabs (spaces) only.
Thank you for your help
RE: save matrix into .txt
Easily done.
The help system explains how to write a text file out. All you have to do is to sub divide the matrix (if necessary) before doing so.
Cheers
Greg Locock
