Need Motor Capacitor
I have a 115 V AC motor and on the name plate it calls for a 20 uF, 200 V capacitor.
Where can I find this capacitor? How does it get hooked up?
The motor only has 3 black wires coming out of it.
Vince
Vince
RE: Need Motor Capacitor
Good Luck.
An online example may be www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611711131&ccitem=
Is it a start capacitor {electrolytic short [4-second] duty, usually round, phenolic case} or run capacitor (continuous duty) film dielectric, usually oval, metal can)? 20 microfarads is more likely for a run application.
www.cornell-dubilier.com/mpdf/runs.pdf
www.mallory-ac.com/AC%20Catalog-2003.pdf
This does sound like a run type capacitor..and connection should be fairly simple to work out as your three wires out will most likely be from two windings, with a common,a run winding lead and a start winding lead.
If you need any more info,refer to:
www.motors-direct.co.uk
A very usefull source of practical advise.
Jeff
