Sampling from gas-liquid stream
Hello
I need some help. I am looking for a sampling equipment for sampling from gas-liquid stream. The relative amounts of gas and liquid in the stream may vary. Do you know any places from where to look for? Or it you know very simple system then i would be very grateful if you could wrote some basics about its construction.
RE: Sampling from gas-liquid stream
Try to contact Bristol Equipment Company,Yorkville Illinois or do it yourself.The main problem is to assure that your sample is representative-it should contain the same ratio of gas/liquid as it is in the bulk. A good turbulence will prevent phase separation at the point of sampling and at the point of measurement.
M777182
