Connect objects
Connect objects
I have two Objects (a simple Box or anything similar). These two objects are connected with a simple Line. Now, when I move one of these boxes I have to manually adjust the connecting Line.
Isn't there a way, the line adjusts itself as it's done in Microsoft's Visio?
This would help me a lot.
Thanks for any Help.
RE: Connect objects
Another option would be to play with a leader (dimension) line. You can associate one end of that with another element.
Finally, if you are not already using Fences, I would suggest you look into them more. They are a very powerful tool that those of us who date back before the Selection Set age are familliar with.
Good Luck,
Robert Weber, EI
Maurer-Stutz, Inc
www.maurerstutzinc.com
www.geocities.com/robntweber
"I am satisfied that your answer is correct. I am not, however, satisfied that your answer is right."
RE: Connect objects
I'll try this.
