LAB RESULTS SO DIFFERENT FROM FIELD
When using a FID or PID on a SVE influent and effluent can someone tell me why lab results are so different from field results.
LAB RESULTS SO DIFFERENT FROM FIELDLAB RESULTS SO DIFFERENT FROM FIELD(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: LAB RESULTS SO DIFFERENT FROM FIELD
The real answer is that PIDs and FIDs are not designed to measure "concentration", and can not be compared to lab results even under the most ideal circumstnces. They should be used as screening tools only.
A better option would be to use an immunoassay kit specific to your contaminant of concern or a portable GC.
However, PID/FID CAN be quite reliable if you treat the instrument as the sensitive detector that it is. Make sure it is properly calibrated daily (or even more frequently) and you should probably set your response factor to 0.5 - give me more details and perhaps I can help you out.
