CBS Wall Crack on Apartment Building Storge Room
The Storage Shed is integral with the apartment complex that was designed and constructed in the '60s in South Florida. The wall contains a crack that runs from the lower block course to the top course under the tie beam. The crack follows the mortar joints up the wall in a zig zag fashion at a general 45-degree angle. Reviewing the plans reveals no steel/filled cells in the wall in the crack area. Any tips on how to assess structural integrity of this structure?
RE: CBS Wall Crack on Apartment Building Storge Room
DaveAtkins
By the way - imagine a line drawn perpendicular to/from the 45 degree crack to the ground - this is most likely where the settlement problem begins.
