Translation Problem - Translation did not complete
I am running NX on a laptop with an XP OS.
I can no longer import iges files as I did at one time on this machine. Now when I import the cmd window will come up for a few seconds and nothing will appear in it and then I get an Error that reads "Translation did not complete".
This is driving me nuts. I think that it has to with virtual memory. Which is set at Int of 384MB and Max of 768MB
Please Help Me
Please Help Me
RE: Translation Problem - Translation did not complete
Do any of your directory paths have spaces in the directory names? If so, get rid of them...this CAN cause problems in UG.
Also, I'm assuming your hard drive is partitioned. Try copying the IGES file to the largest partition. I believe UG writes a temporary part file during the translation then deletes it when you do a save or save as....not quite sure if that is absolutely correct though.
If that doesn't do the trick, I'd suggest logging a call to GTAC.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Star menu >> all programs >> ugnx >> translators >> IGES.
I think if use this way the translation will be completed.
Rgds,
Sormane
Project leader
Mallory LTDA
www.mallory.com.br
