* Welcome *
* Welcome *
Welcome to a discussion forum for
TRUSS Engineering Design, Fabrication, & Useage
http://www.eng-tips.com/gthreadminder.cfm/lev2/99/lev3/100/pid/1066
You can post a new question or comment (please be brief and explanatory).
But first search the thousands of old posted subjects for answers to your questions.
Here's some of the 'Wood Truss' discussions already posted:
Perpendicular load at top plate Thread726-93321
Top Flange Bracing Thread507-87443
Uninhabitable Attics Thread507-93139
Timber Standards Online Thread173-585
Components and Cladding Thread507-92454
Ply gussets in wood truss Thread337-18639
SHEAR TRANSFER TO DIAPHAM Thread726-91119
tension splice in wood truss Thread337-91167
Wood Truss Thread507-91165
Truss plates Thread507-88699
Wood Framing Inspection Thread337-83309
finishing attic - need to span 30' Thread337-87823
Channel-braced flange? Thread507-86850
diaphragm capacity Thread726-86629
Wood Truss Nomenclature Thread507-85520
Line up multi-story wood studs and trusses? Thread507-84758
Any experiences with Architectural Desktop? Thread507-82780
Structural Analysis and Design Software Thread507-602
Plywood Performance as Roof Diaphragm Thread337-79818
Prefab Truss Design Thread507-80024
Joist modification approval? Thread507-79502
A 32’-0” wide building. The floor Thread507-78532
Truss Mod & Repair Thread337-77390
Wood truss connections Thread507-77393
Structural Ridge Beam Size Thread507-75323
Prefab Wood Trusses Thread507-74886
hurricane tie downs Thread507-73040
Wood Truss Plates ??? Thread337-46336
PEMB With Masonry Walls Thread507-73490
Timber Truss Minimum Bearing Thread507-71576
Piggyback wood trusses - connections. Thread507-67869
Plywood roof sheathing deflection Thread337-412
Splicing floor trusses via top and bottom 2x4. Thread337-68808
Nailing roof trusses to interior non-load-bearing walls Thread507-69464
Replacing wood beam with a steel I-beam Thread507-64968
Wood Top Plate Capacity Thread507-18966
Matching wall and truss spacing... Thread337-67105
Floor joist maximum spans Thread507-66817
Corrosion of galvanized plates Thread507-64046
Who is actually designing the trusses? Thread507-63601
Asphalt repair for timber bridge decks Thread194-63746
Wood truss repair fame Thread337-59624
Curved Steel Beams Thread507-62985
Very Concerned - I may have underestimated load Thread507-62418
wood truss with metal plate connectors Thread726-62596
GO BOLTS FOR SHEARWALL Thread726-60519
Russian carpenter needs advice sitebuilt trusses Thread337-61812
Sloped Roof Diaphragm with Ridge Vent Thread726-57855
Scissor trusses and wall attachment Thread507-57317
Truss bottom cords with large knots Thread726-47024
Scissor Truss Bracing Thread337-56213
Old Wood Truss Failure Thread337-19151
Truss uplift -- maybe, maybe not Thread507-51579
specification and detail of press plate trusses Thread337-11117
Hi , need help with analysis of a t Thread337-46767
garage structure (beams) Thread337-50280
Timber deck strong enough? Thread607-38904
Torsion on Wood Members Thread337-47457
Story Drift resistance by post caps only? Thread726-44603
computer programs Thread724-46420
Gusseting Flat trusses with OSB Thread726-44784
roof diaphragm and cathedral ceilings Thread507-45251
Building 'Bangs' in Cold Weather Thread507-43587
Lag bolt spacing in wood connections Thread507-42016
Long Span Wood Trusses Thread337-42602
Software for Structural Design of Dwelling Houses Thread507-19251
Truss Support? Thread337-42393
two story townhouse Thread507-41916
Safe Loading for Wood Truss Thread337-41668
Snow drift on residential buildings Thread507-38880
Wood Truss spacing Thread337-21152
Light Gage Truss - Wood Roof Diaphragm Thread507-40569
6"x6" post strength Thread507-38175
Bowed trussed roof rafter Thread507-37726
steel i beam vs wood beams Thread337-29706
wood I joist Thread507-33898
Existing OWSJ Evaluation. Thread507-30315
wall opening beam sizing Thread507-29564
Truss Design Thread507-29622
Diaphram Design w/o Plywood Thread507-29079
Modifying a common wood truss for extra attic space Thread488-27444
Pitched roof as diaphragm Thread507-22859
Shear walls design at corners in wood w/ plywood sheathing Thread726-15888
I have always calculated the chord Thread507-26143
Tributary Area Thread507-25176
Loading Philosophy Thread507-24332
Beam loading for porch:19'6" span Thread507-22682
ASCE Valley Drift Load Accumulations Thread507-19335
Peeled Log Design Stresses Thread507-18866
Glulam Connections Thread507-17402
Wood Truss Bracing Thread174-12927
SidePlate - Patenting and idea? Thread507-16847
Rafter load sharing Thread507-15245
Erection Methods of Roof Trusses or Structural Steel Thread507-15092
History of Roof Trusses Thread507-15093
Acceptable load on wood bridge Thread507-13240
Siccors Truss Connection Thread507-12135
and more...
and more...
