Non Re- usable pipes.
I am out of my depth perhaps, but, here goes. I need [for a process] to allow fluid into a vessel at just the right amount[this part is ok & resolved]. Then the pipe [which can be in 2 parts]must not be used again [to avoid contamination]. So, the system must break, not fit together again or otherwise be useless. Pipes can be made of plastic, glass, ceramics or similar [not rubber]. Size of pipe varies but never more than 1/2 inch in diameter.
Any help will be most gratefuly appreciated.
RE: Non Re- usable pipes.
What is the length of pipe you are talking about? How many? Do you not have an opportunity to run a CIP and/or SIP cycle? (clean in place/steam in place) In the pharmaceutical/biotech world, that is how we deal with cleaning and sanitizing piping between batches.
Okay, it's sort of the reverse of what you seem to be asking for, but maybe it will get you thinking. I think it's a nice bit of material selection; the doohickey breaks like highly loaded glass- reinforced ABS. The plastic is strong but not tough. The tubing and the bag appear to be polyurethane; tough but not strong. The assembly withstands normal handling but the doohickey can be fractured by a patient's fingers.
-Mike-
