SolidWorks Novell Network Slowness
I was wondering if anyone else noticed a slowness with thier network while using SolidWorks. We use Novell and at always seems sluggish.
I believe it to be our network because when one of us is saving it takes much much more time for another user to create a new part using our part templates which located on the network.
For the most part, all users use their local drive for their work in progress. About 80% of our assembly's, drawings and parts are located on our local drive. The other 20% of our parts that make up our assemblies are located on the network - these are feature palette parts.
When loading assemblies we notice the local drive parts load quickly but the network parts load very slowly.
RE: SolidWorks Novell Network Slowness
There is an area there that talks about Novell Networks. Which by the way, Novell Network is not recommended by SW. Windows networks are.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Anyway, thanks for your comment.
I just read about your issues and sympathize. You're actually parrotting something that we went through a few years back at the company I used to work at. They had (and probably still have) a Novell setup that they were forcing to somehow coexist with Windows.
Anyhow based on that experience, the bottom line is that it is 99.99% certain that Novell is at the root of your performance issues. They attempted a couple of different things to alleviate the problem and only really ever achieved partial success by switching those of us using SW to a dedicated network switch (or other similar piece of hardware). The question was brought up back then as well as to why we were running a Windows network. This question was met with similar angst as mentioned here by others.
As an aside the company I work for now has a Windows network and performs very well in comparison to my previous experience with Novell performance.
Good Luck!
Chris Gervais
Sr. Mechanical Designer
Lytron Corp.
