Error..
Error..
Error..
Hi
I have a part with 15 features and some open bodies and from 6th feature there is a update icon adjuscent. And when I click update its giving me error "No entry found for error id 0x00000001".
I am not able to add any more features or delete anything. Can anyone help me.
Thx.
RE: Error..
FBM....
I don't know what the error message means...
I would suggest deactivating the 6th feature and then do your update.
If the deactivation doesn't cause a lot of problems, then I'd delete that feature and rebuild it.
If the deactivation does create a lot of new problems, then I'd edit that feature and try to determine what is causing the problem.
Good luck,    ....Jack
RE: Error..
Hi Jack
I already solved the problem.You were absolutely right. I deleted that feature and rebuilt it and it worked very fine. I didnt try deactivating it but I am sure that you are correct and would work that way too.
Thx.
FBM
RE: Error..
I had the same kind of problem with a sketch, a line in the sketch was bugged, I replaced it. (Sorry I remember just now)
Don't forget to clean your file after that  ;)
CATDAUV5 is the tools to clean.
Eric N.
catiav5@softhome.net
