tapped shunt 33kV reactor?
Hi all,
Does anyone know of any manufacturer of MV (33kV) shunt tapped reactors that offers a range down to 0 MVARs (or close). Designs based on a single core apparently limit the devices due to volts/turn limits so the ranges can't be say 0-8 MVAR but only say 4-8 MVAr (4MVAr shunt on minimum tap).
This is understandable based on a single winding impedance with a simple tap - are there any other designs out there?
RE: tapped shunt 33kV reactor?
Suggestion: Visit
http://www.thomasregister.com
and type Reactors under Product or Service, which will return 145 companies to approach to
Try Ritz or Trench.
