Can Anyone recomend a spreadsheet solution for Payback Analysis
I am looking for a spreadsheet in Excel that will assist with payback analysis for retro fitting equipment or possibly a software application that does the job.
Jim Furnash
furnashj@ohsu.edu
RE: Can Anyone recomend a spreadsheet solution for Payback Analysis
Jfurnash,
Have you tried doing a search for 'Value Engineering"?
Don Shoebridge
Dayton, Ohio
The birthplace of aviation
Check out my webpage
www.geocities.com/donshoebridge
jfurnash,
I'm assuming that the company that you work for has an accounting department although it looks like you work for a University. The company that I work for has a standardized payback excel sheet. This sheet is proprietary but I can give you the basic formula if you're interested.
Felix Menu
cmenu@prpddmi.com
Felix Menu
DMI - PRPD Engineering
PH.(780) 618-4106
FX.(780) 624-7343
fmenu@telusplanet.net
