300 TON TOP RUNNING CRANE
Need crane information, bridge wt., wheel load, number of wheels and spacing, hoist wt., etc. for a 32 span 300 ton top running crane.
anyone have anything, anything on web?
Thanks much.
alcedo
Thanks much.
alcedo
RE: 300 TON TOP RUNNING CRANE
1. Span of 70 feet (nothing in the span range that you asking for)
2. Has 50 to auxiliary crane
3. Based on C class service
4. Crane can be pendant or cab controlled.
The weight of the trolley 170,000 pounds
The weight of the Crane is 390,000 pounds
Wheel load 100,000 pounds without impact!!
The required rail is 175 pounds (this is pounds per yard!!!)
I have various dimensional facts that would be required for building clearances, etc.
This handbook is very valuable and it is out of print. Give me you e-mail address and I will be happy to fax you the data sheet.
I hope this helps.
Keep in mind that 300-ton cranes are not built everyday. The largest crane that I ever worked on is a 500-ton crane with about 100-foot span with couple of auxiliaries.
Started to e mail one of you guys but did not know how on this site to find the e mail address.
Wishing all the best for the holidays.
alcedo
