New material - defining physical properties
I am trying to define a new plastic material and I cannot find any reference in the help file that will tell me the "code" names for the material properties. I see some in the tutorial (SIGYLD for ex.), does anyone know what they are or where to find them?
RE: New material - defining physical properties
Issue is, that the default SW materials (for plastics and other materials) are incomplete to run a CosmosXpress analisys. What should you do:
1. Create a new databse. Better to crate a copy from the SW original and rename it.
2. If you want to add a new plastic edit one material, say steel, which has all properties you need and change all values to your plastic including names.
3. If you need those values just go to http://www.borealisgroup.com/public/ where you can download for free an exellent applicatin which allows you to update from several other resin producers, the properties you need.
Good luck
