try this out
try this out
try this out
Dear Friend
I am working in catia v5 r12 Try the follwoing see if it works for you.
create a cylinder and create a through hole on cylindrical face and try to give fillet to any one of the hole edges. It selects both edges and gives fillet. It shows only one edge is selected and dose not allow to select second edge.
is there any solution to this
do mail it
amit
RE: try this out
It seems like CATIA's program mistake.
But there is practical solution if you really need only one edge filleted.
First you should chamfer the edge you don't want to fillet with small radius like 0.0001 inch, then you will be able to do fillet on remaining one.
Vladimir, Milford
