How to explode text into lines and arcs?
HI there to all the experts here. I have this problem in auto cad 2002. I need to explode an mtext to lines and arcs coz i need this in machining an embossed text in a product. The problem is i can't explode an mtext. Pls help me. I need this badly. Thanks in advance.
RE: How to explode text into lines and arcs?
If you have Express Tools try "Explode Text".
Or try this lisp:
; TIP #637 XTEXT.LSP By Ashoke Bhattacharya CADalyst Magazine March 1991
; DESCRIPTION:  Explodes a line of text into its component letters.
(princ "\nStart command with XTEXT.")(graphscr)(princ)
(defun C:XTEXT ()
  (setvar "CMDECHO" 0)
  (setq A1 (entget (car (entsel
    "\nSelect text: "))))
  (setq A2 (cdr (assoc -1 A1)))
  (command "ERASE" A2 "")
  (setq A (cdr (assoc 1 A1)))
  (setq SP (cdr (assoc 10 A1)))
  (setq HT (cdr (assoc 40 A1)))
  (setq B (strlen A))
  (setq B1 1)
  (repeat B
    (setq C (substr A B1 1))
    (command "TEXT" SP HT 0 C)
    (setq B1 (+ B1 1))
    (setq HT1 HT)
    (if (= 108 (ascii C))
      (setq HT1 (/ HT 2)))
    (if (= 105 (ascii C))
      (setq HT1 (/ HT 3)))
    (if (= 73 (ascii C))
      (setq HT1 (/ HT 1.5)))
    (setq SP (polar SP 0 HT1))
(redraw)
(princ)
