test method for mercaptans at low concentrations
Hi!
I need to know if it is possible to use liquid or gaz chromatography to analyse mercaptans in White spirit, and the different conditions for this method.
Thanks advanced
RE: test method for mercaptans at low concentrations
hi to you
you can do it on any gas chromatograph equiped with FPD,PFPD detectors, or by using Total Sulfur Analyzer
good Luck
