Tension Load Strenght of a Soldered Copper Pipe Connection
How would you determine the load capacity in tension on a soldered 1/2" coupling for Type K or M copper tubing? Load is hanging.
RE: Tension Load Strenght of a Soldered Copper Pipe Connection
www.engineersedge.com/solder_joint_design/solder_joint_lap_calc.htm
You will need to determine the shear strength of the solder metal - tin base or other alloy?
the shear strength could be calculated if you know the tensile strength of the solder using von Mises criterion where
shear strength = tensile strength/square root of 3
