Dynamic Extrude
Dynamic Extrude
Dynamic Extrude
After NX2 installation I works with new dynamic extrude function (add stroke UGII_NEW_EXTRUDE=613 in ug_metric) After 2.03 qrm installation this function doesn't work. I didn't find any solution in UG_answer. Help please
RE: Dynamic Extrude
Sorry I find a solution to exchange an old extrude to new. But I need a both
RE: Dynamic Extrude
Per UG employee John Baker, if you enable the new extrude, the legacy extrude will no longer be available.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Dynamic Extrude
The only time the old extrude will be available is when you are editing an old extrude.
New extrude = new extrude interface
old extrude = old extrude interface
There is no update path to convert old extrudes to use the new interface.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Dynamic Extrude
Could you possibly make a part with old extrude features and import it into your new part and Reroute the reference curves and modify it using the old extrude functionality.
Michael
0
