Protool V6.0 Passwords
Has anyone set up protool v6.0 passwords for a MP270B panel, using the function 'Logon_user' as it does not appear to do what it implies on the online help. Any help or examples of it use would be appreciated
RE: Protool V6.0 Passwords
What is the exact problem you are having ?
You just have to insert a Password list in one of the screens. Then for the input fields and buttons that you want to protect, set the password level to 1 or higher (default = no password = 0).
There is a superuser password (password level = 9) that you have to use in order to create new users. This password is set under System ... Settings ... OP Password. The dafault is "100", but you can change it to anything.
You probably have to manually write the passwords into normal string tags.
But I must say that I dont understand what you want to do. If the operator simply pushes a button from the startup screen without having to type a password, then where is the user-based sequrity ?
You could use a keyswitch, observe it with a tag via a PLC input, and use that tag to logon a user. Then you have the key as sequrity.
The logout time is for all users.
