absorption chiller performence
Hi all i want to aske about delta t of my abs chiller delta t is only 2c chiller is 330 ton of ref.i want to to the reson pleas help me.
absorption chiller performenceabsorption chiller performence(OP)
Hi all i want to aske about delta t of my abs chiller delta t is only 2c chiller is 330 ton of ref.i want to to the reson pleas help me. Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: absorption chiller performence
Some ideas
1. Improper cooling water temperature.
2. Fouling in heat exchangers.
3. Crystallization.
4. More chilled water flow rate.
5. Insufficient steam pressure.
6. Air leakage and improper vacuum.
Absorption machines also have a number of service valves which contain rubber diaphragms. These service valves perform a variety of functions. Their life cycles are typically three to five years. These valve diaphragms are often the source of air leaks in absorption machines. The removal of the lithium bromide/water charge from the machine every three to five years and replacing these rubber diaphragms is recommended. Removal of the charge also affords an opportunity to examine the solution and refrigerant pumps for wear and tear. It is very important not to introduce air into the machine during
