Japanese Nightmare
Japanese Nightmare
I have a problem with an oil cooled Hitachi-Seiki AC spindle motor. I hope someone can help. "O" ring grooves machined directly into the lamination stack and the stack itself, were designed to seal coolant oil from the rotor/bearing area. After a rewind, we can't get the stator to hold 2 bars of air pressure. Even after epoxy VPI, trickle impregnation, microsealing the stack OD, and even using Glyptol under a vacuum, we still get a leak out of the stator slots at the head of the winding. Any information or someone's past experience to remedy this situation will be greatly appreciated. Thank you.
RE: Japanese Nightmare
