Rising Stem Globe Valve Style Seal
I am tasked with designing a globe valve style seat seal with the following parameters:
150 PSI Max. Pressure
400 F Max. Temp
Fluids to be sealed are steam and or water.
Is there a good resource available which could show me acceptable geometries (angles, finishes, etc...) and seal materials, as well as compression forces required for the seals so that I may size the actuators as well.
All responses are appreciated.
Matt
400 F Max. Temp
Matt
RE: Rising Stem Globe Valve Style Seal
http://www.spiraxsarco.com/default.asp?url=navigation%2Fprod%5Foverview%2Easp%3Fgrp%5Fref%3D4%26sec%5Fref%3D1
