Natural frequency of a cantilevered beam with weight attached.
6
Since there is no response to Thread384-95346 , I would like to re-ask my question in a simpler form:
We have a cantilvered steel beam of length L with weight W2 at distance "a" from the cantilevered end.
What is the resonant frequency?
RE: Natural frequency of a cantilevered beam with weight attached.
if the base is truly fixed (not always correct), the spring rate is
k = (3 E I) / (L^3)
E = elastic modulus
I = section moment of inertia
L = length
If the weight of the beam is negligible compared to the weight at the end, you can just use the mass at the end and the spring rate to calculate the first bending mode natural frequency.
omega = sqrt ( k / Mass)
where omega = radians / second
The next iteration would be to add 25% of the beam mass to this calculation.
If course, we're ignoring higher modes here.
daveleo
I have a paper that derives formulas for various beam configurations, including a mass mounted on the end of a cantilever beam.
Send me an Email if you would like this paper.
Tom Irvine
Email: tomirvine@aol.com
www.vibrationdata.com
hello again
after reading tomirvine's reply, i recalled that about a year ago i posted a small program to calculate beam frequencies (with distributed mass, *but no lumped mass* ) on this website...
http://www.heat-synch.com/Beams/Beams.html
if you click on the image there you should be able to downlaod the executable file.....no instructions....but it should be pretty clear.
daveleo
Rather to my surprise Blevins does not seem to mention this case.
He has solutions for simply supported beams with offset mass loading, but not cantileverss.
Cheers
Greg Locock
I would go about it using the following approximate method. I would treat it as a two degree of freedom system, with two masses and two springs, as in Blevins table 6-2 case 3. I would solve for the lowest frequency - which means taking the negative sign in Blevins formula. I would choose the values of the first mass and spring (closest to the encastre support) such that they formed a lumped mass equivalent of the case in Blevins table 8-8 case 2. I would choose the values of the second mass and spring such that they formed a lumped mass equivalent of Blevins table 8-1 case 3. Whether this will come out anything like the  solution given in Thread 384-95346, I don't know, but I doubt it. It does look as if it might have been derived from a superposition method vaguely like mine however.
there are several approximate methods that work: dunkerley's, rayleighs, and of course finite element.
belief the most direct method is in a mechanical handbook such as mark's.
It is time to wrap up this thread.  Here is the formula for a cantilever beam with a mass attached to the free end.
The fundamental frequency f1 is
f1 = (1/(2 pi) ) sqrt[(3EI)/((0.2235 rho L + m )L^3)]
where
E = elastic modulus
I = area moment of inertia
rho = mass/length of beam
L = length
m = end mass
Tom Irvine
Yes, that equation can be found in numerous places. But that wasn't the original question as I understand it. The mass is only part way along the beam !
EM is correct.  Beam with mass on the end is found several placed. I am looking for beam with mass attached at some point along the beam.
Actually, tomirvines equation is the same as one of the ones I quoted from Blevins, ie table 8-8 case 2. Adding on the extra piece of beam, (table 8-1 case 3) has the effect of reducing the natural frequency, and if the extra piece is very long compared to the first piece, there will be two distinct  and significant natural frequencies - one where the extra piece moves in phase with the Mass, (corresponding to taking the minus sign in the first equation) and a second higher one where it moves in antiphase. My method is not without difficulties, however, since strictly you need to find a way to take into account the fact that the slope at the end of the basic beam and mass must be matched to the added-on piece. Probably can be done though. Thought somebody might have spotted that and jumped on me.
My understanding of Raleigh's method is equate kinetic energy to potential energy.  It requires an assumption on the deflection profile of the beam.
Can I assume for this purpose that the beam (with weight) is deflected in the same manner it would statically deflect under the influence of gravity?
Yes, if you're doing Rayleigh's method, that's generally the assumption you have to make, at least initially.
Much better to use Rayleigh Ritz, using two different curves with an abitrary weighting between them, then differentiate frequency wrt to the weighting factor to find the weighting that gives the minimum frequency.
Another possible method is to use the theory of receptances, which describes how to work out the combined properties of two simple systems, but I am not at all confident that it would work in this case. I'd guess you could consider the separate systems as being a cantilever with a weight on its tip, and another cantilever with its base being moved vertically and rotated. Ug.
Of course for a specific case an FE model is the easiest method, if the least satisfying.
Cheers
Greg Locock
Thank you for the correction, EnglishMuffin.
I just wrote a program using the finite element method to find the natural frequency of a cantilever beam with an added mass at a user-defined length along the beam.
Please contact me if you would like this program.
Tom
Tom,
I just joined after spotting the thread on the cantilever beam natural frequency.  I could use the program you developed to help design a dynamic simulator to replicate various frequency responses of satellite structures.  I am looking for a easy to use tool to determine the configuration of a cantilever beam with moveable mass that will produce frequencies in the range of 18 to 60 Hz for various mass loadings.  Thanks
Here is the source code, written in C/C++.
Tom
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <conio.h>
#include <math.h>
#define MAX 300
void enter_data(void);
void files(void);
void nearest_node(void);
void bc(void);
void symmetry(void);
void global1(void);
void print_global_before_BC(void);
void local(void);
void inverse_iteration(void);
void iteration(void);
void interactive(void);
void kshift(void);
void matrix_times_vector(long nd, double aaa[], double w[][MAX],double bbb[] );
void vector_times_vector(long nd, double *csum, double aaa[], double bbb[]);
void copy_matrix(long nd, double aaa[][MAX], double bbb[][MAX]);
void zero_matrix(long nd, double aaa[][MAX]);
void zero_vector(long nd, double aaa[]);
void print_matrix(long nd, double aaa[][MAX]);
void print_vector(long nd, double aaa[]);
const double TPI = 2.*atan2(0.,-1);
long i,ii,ij,ik,j,jj,jk,k,kk;
long m,n,ne,nn;
int apply;
int iflag;
int nx;
int ipm;
double aa,ah,aj,aq;
double ajl;
double ccc;
double det;
double eigen;
double kd;
double mc;
double length,inertia;
double modulus,mpv,area,mpl,h,load;
double length_mass,cm;
double scale;
double shift=0.;
double x,xx;
double kl[5][5],ml[5][5];
double kg[MAX][MAX],mg[MAX][MAX],gmg[MAX][MAX];
double a[MAX][MAX];
double xi[MAX];
double bb[MAX];
double ac[MAX][MAX];
double ww[MAX];
double b[MAX];
FILE *pFile[20];
char filename[5][20];
void main()
// assume evenly spaced
    printf("\n\n cantilever_with_mass.cpp \n");
    printf("\n ver 1.0  by Tom Irvine   Email: tomirvine@aol.com \n");
    printf("\n This program calculates the natural frequency of a ");
    printf("\n cantilever beam with an added point mass at an ");
    printf("\n arbitary point along the length of the beam. \n\n");
    printf("\n enter data \n");
    enter_data();
    printf("\n files \n");
    files();
    printf("\n local \n");
    local();
    printf("\n global1 \n");
    global1();
//    axial_stiffness();
    printf("\n symmetry \n");
    symmetry();
    if( ipm==1)
        printf("\n cm=%12.4g \n",cm);
        mg[nx][nx]+=cm;
    printf("\n print global before BC \n");
    print_global_before_BC();
    printf("\n bc \n");
    bc();
    printf("\n inverse iteration \n");
    inverse_iteration();
    for(i=1; i<=nn; i++)
        for(j=1; j<=nn; j++)
            fprintf(pFile[2]," %11.4g",mg[i][j]);
        fprintf(pFile[2],"\n");
            fprintf(pFile[2]," %11.4g",kg[i][j]);
void symmetry(void)
    //  symmetric
        for(j=i+1; j<=nn; j++)
            kg[j][i]=kg[i][j];
            mg[j][i]=mg[i][j];
void bc(void)
    // cantilever bc
    for(i=3; i<=nn; i++)
        for(j=3; j<=nn; j++)
            fprintf(pFile[3]," %11.4g",mg[i][j]);
        fprintf(pFile[3],"\n");
            fprintf(pFile[3]," %11.4g",kg[i][j]);
    fclose(pFile[3]);
    n=0;
            mg[i-3][j-3]=mg[i][j];
            kg[i-3][j-3]=kg[i][j];
        n++;
void files(void)
   strcpy(filename[1],"km.out");
   pFile[1]=fopen(filename[1], "w");
   strcpy(filename[2],"kmg.out");
   pFile[2]=fopen(filename[2], "w");
   strcpy(filename[3],"kmbc.out");
   pFile[3]=fopen(filename[3], "w");
   strcpy(filename[4],"eigen_data.out");
   pFile[4]=fopen(filename[4], "w");
   printf("\n");
   for(i=1; i<=4; i++)
      if(pFile[i] == NULL )
         printf(" Failed to open file: %s \n", filename[i]);
         fclose(pFile[i]);
      else
         printf(" File: %s opened. \n", filename[i]);
    double xr;
    long matrix_point=1;
    double min = 2*length;
    double hh=length/double(ne);
    for(i=0;i<=ne;i++)
        x=i*hh;
        xx = fabs( x -length_mass);
//        printf(" x=%10.3g  xx=%10.3g  min=%10.3g\n",x,xx,min);
        if(xx < min )
            min=xx;
            nx=matrix_point;
            xr=x;
        matrix_point+=2;
//    printf("\n xr= %12.4g   nx= %ld  min=%12.4g\n\n",xr,nx,min);
void global1(void)
    for(i=0; i<100; i++)
        for(j=0; j<100; j++)
            kg[i][j]=0.;
            mg[i][j]=0.;
//    printf("ref3b  k11=%lf \n",kl[1][1]);
       for(m=1; m<=ne; m++  )
        i=2*m-1;
        kg[i][i]  +=kl[1][1];
        kg[i][i+1]+=kl[1][2];
        kg[i][i+2]+=kl[1][3];
        kg[i][i+3]+=kl[1][4];
        j=i+1;
        kg[j][j]  +=kl[2][2];
        kg[j][j+1]+=kl[2][3];
        kg[j][j+2]+=kl[2][4];
        j=i+2;
        kg[j][j]  +=kl[3][3];
        kg[j][j+1]+=kl[3][4];
        j=i+3;
        kg[j][j]  +=kl[4][4];
        mg[i][i]  +=ml[1][1];
        mg[i][i+1]+=ml[1][2];
        mg[i][i+2]+=ml[1][3];
        mg[i][i+3]+=ml[1][4];
        j=i+1;
        mg[j][j]  +=ml[2][2];
        mg[j][j+1]+=ml[2][3];
        mg[j][j+2]+=ml[2][4];
        j=i+2;
        mg[j][j]  +=ml[3][3];
        mg[j][j+1]+=ml[3][4];
        j=i+3;
        mg[j][j]  +=ml[4][4];
    printf("\n Enter length (inch)\n");
    scanf("%lf",&length);
    printf("\n Enter area moment of inertia (inch^4)\n");
    scanf("%lf",&inertia);
    printf("\n Enter cross-section area (in^2) \n");
    scanf("%lf",&area);
    int imat;
    printf("\n Enter material ");
    printf("\n 1=aluminum ");
    printf("\n 2=steel ");
    printf("\n 3=other \n");
    scanf("%d",&imat);
    if( imat==1)
        modulus = 1.0e+07;
        mpv = 0.1;
    if( imat==2)
        modulus = 3.0e+07;
        mpv = 0.28;
    if( imat != 1 && imat !=2)
        printf("\n Enter elastic modulus (lbf/in^2)\n");
        scanf("%lf",&modulus);
        printf("\n Enter beam mass per volume (lbm/in^3) \n");
        scanf("%lf",&mpv);
    printf("\n Beam mass = %8.3g lbm \n",length*area*mpv);
    mpv/=386.;
//    printf("\n Enter compressive load (lbf) \n");
//    scanf("%lf",&load);
        load = 0.;
        printf("\n Enter number of elements. (suggest 8 or more) \n");
        scanf("%ld",&ne);
        printf("\n\n Add point mass ? ");
        printf("\n 1=yes  2=no \n");
        scanf("%d",&ipm);
        if(ipm==1)
            printf("\n Enter distance from fixed end to concentrated mass (inch)\n");
            scanf("%lf",&length_mass);
            printf("\n Enter concentrated mass (lbm)\n");
            scanf("%lf",&cm);
            cm/=386.;
            nearest_node();
    mpl=mpv*area;
//    printf("\n mpl= %12.4g\n",mpl);
//  printf("\n h= %12.4g\n",h);
    mc=h*mpl/420.;
//  printf("\n mc= %12.4g\n",mc);
    nn=2 + (ne*2);
    n=nn;
void local(void)
    ml[1][1]=156.*mc;
    ml[1][2]=22.*mc;
    ml[1][3]=54.*mc;
    ml[1][4]=-13.*mc;
    ml[2][2]=4.*mc;
    ml[2][3]=13.*mc;
    ml[2][4]=-3.*mc;
    ml[3][3]=156.*mc;
    ml[3][4]=-22.*mc;
    ml[4][4]=4.*mc;
    double kc=modulus*inertia/pow(h,3.);
    kl[1][1]=12.*kc;
//    printf("ref1  k11=%lf \n",kl[1][1]);
    kl[1][2]=6.*kc;
    kl[1][3]=-12.*kc;
    kl[1][4]=6.*kc;
    kl[2][2]=4.*kc;
    kl[2][3]=-6.*kc;
    kl[2][4]=2.*kc;
    kl[3][3]=12.*kc;
    kl[3][4]=-6.*kc;
    kl[4][4]=4.*kc;
    for(i=1; i<=4; i++)
        for(j=1; j<=4; j++)
            fprintf(pFile[1]," %12.4g ",ml[i][j]);
        fprintf(pFile[1],"\n");
    for(i=1; i<=4; i++)
        for(j=1; j<=4; j++)
            fprintf(pFile[1]," %12.4g ",kl[i][j]);
    fclose(pFile[1]);
    printf("\n inverse_iteration.cpp, ver 1.1, February 19, 2004");
    printf("\n\n by Tom Irvine ");
    printf("\n Email:  tomirvine@aol.com ");
    printf("\n\n This program uses inverse iteration to determine the lowest ");
    printf("\n eigenvalue and vector of the generalized eigen problem: \n\n");
    printf("\n     K - lambda M = 0");
    printf("\n\n where K and M are symmetric matrices.");
    interactive();
    if(apply==2)
        kshift();
    iteration();
    double ddd=0.;
// printf("\n initialization" );
//       printf("\n n= %ld \n",n);
       for(i=0;i<MAX;++i)
          xi[i]=double(i);
       zero_vector(MAX, bb);
       zero_vector(MAX, ww);
       zero_matrix(MAX, ac);
/****  copy data into reserve matrices  **/
    long ijkl;
    for(ijkl=0; ijkl<40; ijkl++)
       copy_matrix(n, a, kg);
       copy_matrix(n, ac, kg);
       copy_matrix(n, gmg, mg);
       matrix_times_vector(n, b, gmg, xi );
/****** begin forward elimination  *********/
//       printf("\n begin forward elimination \n" );
       for(i=0;i<n;++i)
//           printf(" %d ",i );
           aq=fabs(a[i][i]);
           for(jj=i+1;jj<n;++jj)
//              printf("\n switching");
              ah=fabs(a[jj][i]);
              if(aq<ah)
                 aq=fabs(a[jj][i]);
                 for(kk=0;kk<n;++kk)
                     ww[kk]=a[jj][kk];
                      a[jj][kk]=a[i][kk];
                      a[i][kk]=ww[kk];
                 aj=b[jj];
                 b[jj]=b[i];
                 b[i]=aj;
           for(j=i+1;j<n;++j)
               if(  fabs( a[i][i] ) < 1.0e-20  )
                   printf("\n diagonal term  %d %d equals zero ",i,i);
                   exit(1);
            ik=i+1;
            for(ii=ik;ii<n;++ii)
                aa=a[ii][i]/a[i][i];
                b[ii]+=-b[i]*a[ii][i]/a[i][i];
                for(j=i;j<n;++j)
                   a[ii][j]+=-aa*a[i][j];
                   if( fabs(a[ii][j]) <1.0e-10)
                       a[ii][j]=0.;
/********* back substitution ***********************************/
//       printf("\n begin back substitution ");
       b[n-1]/=a[n-1][n-1];
       for(i=n-2;i>=0;i=i-1)
            for(k=i+1;k<n;++k)
//                 printf("\n %d %d",i,k);
                 b[i]+=(-b[k]*a[i][k]);
            b[i]/=a[i][i];
// xt M x
       matrix_times_vector(n, bb, gmg, b );
       vector_times_vector(n, &ccc, bb, b);
       ccc =sqrt(ccc);
       for(i=0;i<n;++i)
           b[i]/=ccc;
           xi[i]=b[i];
       matrix_times_vector(n, bb, ac, b );
       ddd=0.;
       vector_times_vector(n, &ddd, bb, b );
//       printf(" ccc = %lf   ddd = %lf \n",ccc,ddd);
       ccc/=ddd;
// eigenvector
   printf("\n\n Fundamental frequency \n\n");
    fprintf(pFile[4],"\n\n Eigenvalue \n\n");
       ccc+=shift;
//       printf("   lambda = %12.5g \n",ccc);
//       printf("    omega = %12.5g \n",sqrt(ccc));
       printf("       fn = %12.5g Hz\n",sqrt(ccc)/TPI);
    fprintf(pFile[4],"     lambda = %12.5g \n",ccc);
    fprintf(pFile[4],"      omega = %12.5g \n",sqrt(ccc));
    fprintf(pFile[4],"         fn = %12.5g Hz \n",sqrt(ccc)/TPI);
//   printf("\n\n Eigenvector \n\n");
fprintf(pFile[4],"\n\n Eigenvector \n\n");
       fprintf(pFile[4]," 0. \t  0.  \t 0. \n");
       k=1;
       for(ij=0;ij<n;ij+=2)
//             printf("  %d %12.5e \n",ij,b[ij]);
            fprintf(pFile[4]," %12.5e \t %12.5e \t %12.5e \n",k*h,b[ij],b[ij+1]);
             k++;
  apply = 1;
  shift = 0.;
void kshift(void)
        for(i=0; i< n; i++)
            for(j=0; j<n; j++)
               kg[i][j]-= shift*mg[i][j];
void matrix_times_vector(long nd, double aaa[], double bbb[][MAX],double ccc[] )
       long i,j;
       for(i=0;i<nd;++i)
            aaa[i]=0.;
            for(j=0;j<n;++j)
                 aaa[i]+=bbb[i][j]*ccc[j];
       long i;
       *csum=0.;
       for(i=0;i<nd;++i)
            *csum+=aaa[i]*bbb[i];
       long i,j;
       for(i=0;i<nd;++i)
   &nb
With this canilevered spring arrangement,vibrating at natural frequency, is there a natural amplitude of vibration? If so what is the formula?
with all due respect how do you have "cantilever" boundary conditions on satellite structures...
geoffthehammer, no there isn't. If you apply more excitation you'll get a bigger response. You'll almost certainly need to know the damping as well.
hacksaw, well, a 1 kg mass fixed via a cantilever to a 100 kg satellite is pretty much going to behave like the simple model says.
Cheers
Greg Locock
that is okay as long as you are only focusing on the cantilever tip
Tom:
That's anice simple expression for the mass at the end of the beam,  but is the ".2235" constant in any wise dependent on whether one is using inches, centimeters, meters, pounds, kg, etc.?
RC
Don't think so, dimensional analysis tells you it is non-dimensional
Cheers
Greg Locock
