Seal/cooling liquid for liquid ring vacuum pump
Can any fluid be used for seal/cooling fluid in a liquid ring pump e.g. crude oil (gas a gas application)?
Best regards
Morten
Best regards
Morten
RE: Seal/cooling liquid for liquid ring vacuum pump
Is this subject anything like what is in Thread1036-93865?
Art Montemayor
Spring, TX
nearly any liquid is suitable but pls. check
- vapour pressure(s) (because of cavitation and because of a possible loss of capacity if a fraction is condensing during compression and reflashing at the inlet)
- viscosity (start conditions, power absorbed,..)
- specific heat (the highest the best, as the seal liquid will have to evacuate the heat)
- solubilty of gas in the seal liquid (possible re-flashing at inlet condition).
- pump and seals materials
PST
www.vacuum-guide.com
Thank you for your input.
Best regards
Morten
