IC for a reversing type motor
I need to operate a 12VDC 2-wire PM motor in both directions. I will be interfacing it through a microcontroller. What i am asking is if there is an IC that operates on 5V and can control the 12V (and polarity) that will control the motor.  Or is there a method anyone can suggest with maybe using a solid state relay IC and another IC.  I just need to be able to operate a motor in forward and reverse through programming and not by physically switching the polarity on the motor terminals.
Thanks for the help.
RE: IC for a reversing type motor
Search the web for a thing called an "H-Bridge"....
Have a look at motor control IC's at ST Microelectronics
http://www.st.com/
How much is the current?
<nbucska@pcperipherals DOT com> subj: eng-tips
The motors will be drawing approximately 4amps
Try a DPDT relay.   It can easily be operated by 5V electronics, and has a higher current carry capacity than most simple IC solutions.  Otherwise, you may need to build your own H-bridge out of several discrete components... but if you need to go that route, you can check out International Rectifier (www.irf.com) to look at the drivers and transistors needed.  I think the relay is easier to understand, and quicker to develop, and might be cheaper too.
