Greek Letters in Modules
hi,
I am looking for help on 2 issues and will appreciate any input.
1--I have a macro which results in displaying a mathematical expression(string) in a cell using some of the string and text functions. How can Greek symbols such as PI or PHI be included within the module functions so they end up in the final expressions? or can it be done at all?
2--How can a single module be protected or hidden by assigning a password.
Thanks.
Thanks.
RE: Greek Letters in Modules
TTFN
about your #1, try this macro.
It reads from cell B2 a circle diameter (e.g. B2 value= 1.5) and writes in B3 its area expliciting PI.
Also it writes in B5 a sentence using mixed Arial and GreekC font (of course you can specify a different one).
Hope it helps.
_LF
Sub GreekInCell()
Range("B3").Select
ActiveCell.FormulaR1C1 = Str(Range("B2").Value ^ 2) & "*p/4"
N% = Len(Range("B3"))
With ActiveCell.Characters(Start:=N% - 2, Length:=1).Font
.Name = "GreekC"
.FontStyle = "Regular"
End With
Range("B5").Select
DD$ = "First letters of Greek alphabet are: ": U% = Len(DD$) + 1
DD$ = DD$ + "a(alpha), ": D% = Len(DD$) + 1
DD$ = DD$ + "b (beta), ": T% = Len(DD$) + 1
DD$ = DD$ + "g (gamma)"
ActiveCell.FormulaR1C1 = DD$
With ActiveCell
.Characters(Start:=U%, Length:=1).Font.Name = "GreekC"
.Characters(Start:=D%, Length:=1).Font.Name = "GreekC"
.Characters(Start:=T%, Length:=1).Font.Name = "GreekC"
End With
End Sub
e.g type [Alt] + 0248 to get ΓΈ.
Check what's available in the character map.
from within the vba module, select Tools - VBAProject Properties...
select the protection tab.
have fun and good luck!
-pmover
sdz,
very helpful pointer. I cant however find an "Alt+..." keystroke for the greek letter "Pi". Am I missing it? It seems that only some of the characters have the "Alt+..." keystroke associated with them.
Thanks again
Am I missing something?
I'm not sure how you would do it if you want to generate text in a module for display in a sheet.
